An unknown LACP PDU sub type has been received while calling the checkpointing routine. Possible PDU data corruption
Check the message ID parameter, if valid. Also, look in to the check point BPDU. show lacp counters show lacp member-port <port> {detail}
Warning
Received unknown PDU subtype: %type%. Port: %port%
| Name | Type |
| type | uInt32 |
| port | String |
